Hi everyone,
I'd like to create an automation rule.
Our goal is to freeze a project without activity under 2 weeks, then archive this project if there is no activity during 4 weeks.
Do you think this rule could be set?
Could you please help me?
Best regards
Karim
Hi Kmerovil,
There is no automation rule that will allow you to do a freeze or archive a project, those are administrative task meant to be done by a Jira Admin.
sorry for not being more useful. Cheers,
Nico
Thanks so much for your feedback.
I guessed this move was not possible but we never know.
Thanks for your help.
Karim
Hi @KMEROVIL
Welcome to the community!
Which version of Jira are you using?
As mentioned by @Nicolas Tagle there is no out-of-the-box feature to do this automatically.
In Jira 8.20.x onwards, there is a 'Clean up' option in the 'System' section where you can sort the projects by when the issue/ ticket was last created and archive them accordingly. Unfortunately, this is a manual process.
Please refer to this as well: https://confluence.atlassian.com/clean/cleanup-guide-1018788576.html
Hope this helps.
Vamsi
Hi @Vamsi Kandala ,
Thanks so much for your feed back.
I am using the 8.20 Datacenter version.
I'll try it and let you know.
Best regards
Karim
