×I'd like to get Project Form Template Data and maybe create one using REST APIs.
I'm using OAuth 2.0 (3LO) to generate access token and perform rest api calls.
So far, I tried to do it via docs and all but unable to get any results.
Endpoint I'm trying:
https://api.atlassian.com/jira/forms/cloud/cloud-id/project/project-key/form
it's 401: Unauthorized but with the same access token i'm able to fetch projects, issues, etc.
Scopes I'm using:
You are using Forge for this right? Have you tried with Postman and the basic auth?
