Get all issue for jira
Mertcan Karabaş May 10, 2024
Hello, I want to bring all issues in Jira or certain issues with JQL through my application. I can get a single issue by sending a request as /rest/api/3/issue/T1-1. However, when I request /rest/api/3/search?jql=..., I get the error {“code”:401,“message”:“Unauthorized; scope does not match”}.
Here is my code below:
try {
    if (issueIdOrKey === undefined || issueIdOrKey === null) {
        response = await api.asUser().requestJira(route`/rest/api/3/search?`, {
            headers: {
                 'Accept': 'application/json'
    } else {
         response = await api.asUser().requestJira(route`/rest/api/3/issue/${issueIdOrKey}`, {
            headers: {
    console.log(`Response: ${response.status} ${response.statusText}`);
    return await response.json()
} catch (error) {
console.error('Error:', error);
throw error;
Here is my permissions below:
permissions:
    scopes:
    - 'read:jira-work'
    - 'read:issue-meta:jira'
    - 'read:issue-security-level:jira'
    - 'read:issue.vote:jira'
    - 'read:issue.changelog:jira'
    - 'read:avatar:jira'
    - 'read:issue:jira'
    - 'read:status:jira'
    - 'read:user:jira'
    - 'read:field-configuration:jira'
Vijay Dadi
May 10, 2024
Hi @Mertcan Karabaş ,
You have to use base64 encoded api token.
Hi @Vijay Dadi
Where do in the code should I add the base64 api token? and how can i get this token? If I need to create and use 'https://id.atlassian.com/manage-profile/security/api-tokens' from here, how can I request this from users?
Vijay Dadi
May 10, 2024
The api token has to be generated for your service account one time and can be re-used. Once you encode it for base 64, use it in your header as
'Authorization': 'Basic <base64 encoded api token>'
I'm using macOS and I created the base64 token in the terminal like this:
echo -n my_mail@gmail.com:my_api_token | base64
headers: {
'Accept': 'application/json',
'Authorization': 'Basic a2FyYWJh...'
then i added to my header but i got same error. Could there be another problem?
Hi, @Vijay Dadi
I solved the problem and the reason was from a different part of the code. I was checking whether the input I received was undefined or null and that's why it was entering the second if block. Therefore, since the request was sent as rest/api/3/issue/, it gave an error. Again, thank you very much for your help.
