Get issues by project key with all work logs
nttinhcmus February 18, 2020
Hey guys, I am using JIRA api version 7.6.1 on method GET /rest/api/2/search.
My problem is the number of work logs received is only 20 as default.
Is there away to get all work logs inside an issue. As In the image I have 25 work logs for the issue but can get only 20.
"id": "15430",
"self": "",
"key": "DHC-157",
"fields": {
"summary": "Display Payment Plan in Cart",
"worklog": {
"startAt": 0,
"maxResults": 20,
"total": 25,
"worklogs": [
"self": "h8",
"author": {
Petter Gonçalves
February 19, 2020
Hello @nttinhcmus
Thank you for reaching out.
Indeed, the Rest API call /rest/api/2/search is limited to 20 worklog entries per issue. We have a bug reported about this behavior here:
The /rest/api/2/issue/<issueKey> endpoint does not respect pagination parameters
Feel free to vote and watch the bug to increase its priority and also receive notifications about its fix implementation.
As a workaround, you can use the /rest/api/2/issue/<issueKey>/worklog endpoint to list all worklogs for a given issue. Additional manipulation will be required by the REST consumer to sort or filter those results; as that endpoint does not support pagination either. Please see JRASERVER-69308 for more details.
Let us know if you have any questions.
nttinhcmus February 19, 2020
Thank you @Petter Gonçalves  for the answer. It's very clear to me.
I have the same idea of using the /rest/api/2/issue/<issueKey>/worklog endpoint to list all worklogs but what I concern is the performance.
Btw, I have to go on that way.
Thank you again and have a nice day!
Petter Gonçalves
February 20, 2020
Hello @nttinhcmus
You are welcome! Have a nice day you too and please don't hesitate to contact us again in case you have any other questions. :)
