Getting Error with Traffic Lights for Jira plugin custom field when import with ProjectConfigurator
Shirley He
When importing a project with project configurator, we get the following errors
INFO 14:41:41,041 Project Import: Validation errors were found. The import cannot continue.
ERROR 14:41:41,041 The custom field 'X' requires option with parent '???' and value '(,,#9E6DB3) Escalation' for the import but it does not exist in the current JIRA instance.
ERROR 14:41:41,041 The custom field 'X' requires option with parent '???' and value '(,,#FFC200) Amber' for the import but it does not exist in the current JIRA instance.
ERROR 14:41:41,041 The custom field 'X' requires option with parent '???' and value '(,,red) Red' for the import but it does not exist in the current JIRA instance.
ERROR 14:41:41,041 The custom field 'X' requires option with parent '???' and value '(,yellow,) Yellow' for the import but it does not exist in the current JIRA instance.
ERROR 14:41:41,041 The custom field 'X' requires option with parent '???' and value '(chartreuse,,) Green' for the import but it does not exist in the current JIRA instance.
ERROR 14:41:41,041 The custom field 'X' requires option with parent '???' and value '(chartreuse,yellow,) Chartreuse' for the import but it does not exist in the current JIRA instance.
It seems there is a problem with the Traffic Lights for Jira plugin by Service Rocket. We've tried changing the values but that doesn't fix anything. It seems the error is with parent "???," however we don't know where to find that and change it. Any help would be appreciated.
Sid
December 24, 2018
Hi @Shirley He,
Does you have the plugin configured in the new instance as well?
shows there is no required plugins in the new instance.
Shirley He
No, we didn't configure anything in the new instance. Any configuration that exists was created during project import. We are trying to change configurations now, but cannot find "parent"
Shirley He
By the way, could you please give some advice on how to properly configure Traffic Lights?
Sid
December 24, 2018
Here the issues data are dependent on the Traffic light plugin. So in order to have the successful import you also need to have the dependent plugins in the new instance.
If you don't want the traffic lights, then you need to delete the values before the import
To configure the plugin -
  1. Log into your new Jira instance as an admin.
  2. Click the admin dropdown and choose Add-ons. The Find new apps or Find new add-ons screen loads.
  3. Locate Traffic-Lights for Jira. Install it
  4. Give the valid license and you are all set. (reindex may require)
For additional docs - https://polscheit.atlassian.net/wiki/spaces/TRAFFIC/pages/110755841/Administration+Automation
Sid
December 24, 2018
Importing complete projects
Import of complete projects (i.e their configuration, issue data and attachments) is subject to the restrictions described in this page, especially:
  • Jira versions of the source and target instances must be identical.
  • If the source instance had any custom field plugins installed when the backup file was created, and the custom field was used in any of the exported projects, then the target instance of Jira must have the same version of the plugins installed
  • Your instance of Jira will be locked out during the actual data import (not during the validations), so please ensure that your instance does not need to be accessible during this time.
  • The timezone of the source instance must be the same as that of the target instance. Otherwise, the import would be affected by JRA-26039 and imported dates would not be correct.
Sid
December 24, 2018
If the issue is solved, please accept and vote for answer
