I have used the GitHub Jira integration app from Atkassian. evenything is connected properly (as per the prompts) however i can't seem to get GitHub to display the link to Jira
on jira i can see the commits though
Hi @Vijendra Malhotra and welcome to the community!
To create links from GitHub to Jira, you need to set up "Autolink references" in GitHub. Here's how to do it:
This setup will enable automatic linking between your GitHub commits and your Jira tasks.
I had the same issue where I saw the commits in Jira but no links in e.g. PR descriptions. I found that if I wrote:
[PROJECT-103] (instead of `PROJECT-103`), it did link.
thanks for this.
Do i have to do this manual setup for all my repos ?
I think you have to enter this per repo. Different repos might go to different Jira projects, and then you need to refer to the correct Jira-/ProjectKey.
If the solution solved your problem, it would be nice if you could accept the answer below (then the post will be marked as solved). Hava a nice day! :)
