I have two projects, say Project A and Project B. In Project A, I have one board, PAB1, in Project B I have two, PBB1 and PBB2. I want to give read access to a user for all boards in Project B, so PBB1 and PBB2, and write access for one board in Project B, say PBB1. This user shouldn’t have any access to Project A and its board.
How can I manage this?
Hi @Xavier Roy
I see three needs above:
Just to be clear up-front:
Project A - Restrict Access:
You can control access using Project Permissions. As a Jira/Site Admin:
If you are creating a new user group or need new project roles for this scheme, manage this via:
Project A - Board Access:
If a user doesn't have access to view a project's issues, the board will show as blank. However, if you also want to hide the board.
As a Board Admin/Filter Owner:
Project B:
It's not possible to limit edit access based on a board. A board is just a visual representation of an issue filter. You can restrict board visibility using the same instructions as above.
Permissions are all decided from a project-level.
Depending on your scenario - some options are:
If you could provide us some further information about the need in Project B, we'd be happy to try and find a solution :)
Ste
Hi @Ste Wright ,
Thanks for the detailed answer, this is very helpful.
Project B is a product we are developing and boards PBB1 and PBB2 would be two clients we develop this product for.
Ideally a developer of Product B should have the permissions to follow the development made on PBB1 and PBB2 and edit only the development they’re doing themselves on, say, PBB1.
The way I’ve created and deal with these two boards PBB1 and PBB2 is as follows:
This is a good framework so far, but I’m in now way restricted to it.
Commenting on your bullet points:
Thanks for the link on that last bullet point, I’m not familiar with how these work, does it sound like the framework I’m using could use the workflows?
I’ll have a read at the doc you linked to, thanks again.
Hi @Xavier Roy
If you were to use the workflow option, you'd need a separate issue type per edit restriction - so it just depends how many limitations you need to apply.
Another option you have within the same project is Issue Security - it is visibility rather than just edit access, but offers some flexibility within the parameters of the project itself.
Ste
