Hi there
Why would a global rule work in 1 project and not the other?
The rule does the following:
When the status changes to 'in progress' in one of the projects, the status in the service management project/workflow must change to 'development'. The rule works for 1 project but not the others. Here is the rule
Hi Thembisa,
Are there any conditions or validators on the transition to Development for the workflow attached to the project that is not working?
Are the projects using the same or different workflows?
Hi John
Sorry for the delayed response, I was on leave.
All projects are using the same workflow and there are no predefined validators to or from that development status
One more question to try to help: is this rule for company-managed or team-managed projects, or both?
Thanks for that information.
Repeating John's request: would you please post an image of the audit log details, showing what happens for the rule for that project that doesn't work as you expect?
Hi @Bill Sheboy @John Funk @Fabian Lim
Below is the error I was getting. I haven't touched the rule since I left (I checked config changes in case anyone else did) but I just tested now and it suddenly works, not sure what happened. Do you have any idea?
Thanks all for your help by the way
Thanks, @Thembisa Ndlamlenze
One cause of that error is when the transitioning issue does not have the selected status in its workflow. For example, when the source issue (of the status) is a different issue type than the destination one. Have you checked if there have been changes to workflow for the destination issue's Issue Type?
The other cause I have seen for this error is when there are multiple statuses defined with a Status Name (and so they have different Status ID values). The transition is trying to use one that is not supported by the destination issue type's workflow.
Welcome to the community.
Have you checked the audit logs and see if there are any error messages?
Regards
Thanks Fabian
Error
Destination status could not be resolved. If using a smart-value ensure this resolves to a numeric status ID or untranslated name for issues (with current status):
Most likely the ticket that you are trying to transition does not have a transition to the development state. Make sure that the workflows are the same.
Also, make sure that whoever is executing the rule also has permissions to transition the ticket.
Hi Fabian
All projects are using the same workflow and yes I have permissions
