Global automation, transition issue based on status - status not found
Meytal BM
August 17, 2021
I tried to use global automation with Issue Transitioned. When i look for the Start or To Status, it does show the status I am looking for. Actually it doesn't show all Statuses created in the Jira cloud instance i am using. Why is that and how can this be resolved?
Nir Haimov
Hi @Meytal BM
make sure in the automation rule config itself, the rule is set for "all projects" and not a specific one.
Meytal BM
August 17, 2021
Hey @Nir Haimov , thanks a lot, but how do i do that in global automation?
Meytal BM
August 17, 2021
Is seems like now it is working properly. perhaps it was an index issue to bring all the status values.
Nir Haimov
