Hi All,
I have a workflow button "In progress" which helps me to move forward in the ticket life cycle.
In the workflow post function: I want 2 things to happen:
1) Update a Select list based on a condition: I am using below script for this:
cf.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(cf), option), changeHolder);
2) Since I am using 5 select lists, based on their values, i need to move ticket to a particular stage in workflow, say "Intermediate". I am using the below script for this:
WorkflowTransitionUtil workflowTransitionUtil = JiraUtils.loadComponent(WorkflowTransitionUtilImpl.class);
workflowTransitionUtil.setIssue((MutableIssue)issue);
workflowTransitionUtil.setUserkey(currentUser.getKey());
workflowTransitionUtil.setAction(301);
if (workflowTransitionUtil.validate().getErrorMessages().size() == 0)
workflowTransitionUtil.progress();
2 scripts in my post function, however to execute them both, I need to press "In progress" button twice in my Ticket view window.
Am i missing something ? is there way to combine both the scripts to 1 to avoid pressing the button twice?
Please help
Workflow transitions in post function scripts is generally a bad idea. Please reconsider your workflow.
"generally a bad idea" - that is a very polite way of saying "do not do this".
Hi @Nic Brough -Adaptavist- @Danyal Iqbal
the requirement states that based on the value of 5 Select lists(which are updated via post function) , ticket either needs to move to Stage A or B or C.
Any other way to accomplish this?
Use Scriptrunner's "fast track transition" function. This moves an issue on without the horror of trying to do a transition inside a transition inside a transition inside a transition inside a transition inside a transition inside a transition ...
Thanks @Nic Brough -Adaptavist-.
But with the help of Fast Track Transition an issue, can the transition for subtasks also be made i.e.
based on the value of 5 Select lists(which are updated via post function in the parent), if subtask needs to move to stage A or B or C?
That is not what your original question asked.
You can transition other issues in a post-function, you don't need the fast-track - that is only for the current function.
