Groovy Script to create Jira Workflows with conditions, validators and postfunctions
Deleted user May 8, 2019
Hi all,
I'm trying to create a workflow from groovy script in order to replicate it multiple times. Is there anyone that has already do this ?
Thanks in advance.
Bhushan Nagaraj
May 8, 2019
@[deleted] , if you are using ScriptRunner, this is available as a built-in post-function script. Please take a look at the documentation at https://scriptrunner.adaptavist.com/5.4.47/jira/builtin-scripts.html#_clones_an_issue_and_links
Cheers
Bhushan
Deleted user May 10, 2019
Hi Bhushan,
I need to move the same WF from a Jira instance to another without replace manually all ids (maybe others activities) and with all customization Jira's built-in and generated using plugis (i.e. groovy scripts with JMWE or ScriptRunner).
Are there a solution ?
I also need a method to automatically create screens and relative screens.
Thanks.
Alessio
Bhushan Nagaraj
May 12, 2019
