Groovy condition for 'Issue was in status'
Rob B
February 26, 2020
Im doing a condition to be ....
Issue was previously in status 'Review'
This is basically so i can set a resolution depending on what route the user went around the workflow.
Payne
February 27, 2020
Here is an example of running JQL in a script:
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.issue.search.SearchResults
import com.atlassian.jira.user.util.UserUtil
import com.atlassian.jira.web.bean.PagerFilter
String jqlSearch = "status changed from \"Status 1\" to \"Status 2\""
SearchService searchService = ComponentAccessor.getComponent(SearchService.class)
UserUtil userUtil = ComponentAccessor.getUserUtil()
ApplicationUser user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
IssueManager issueManager = ComponentAccessor.getIssueManager()
List<MutableIssue> issues = null
SearchService.ParseResult parseResult = searchService.parseQuery(user, jqlSearch)
if (parseResult.isValid()) {
SearchResults searchResult = searchService.search(user, parseResult.getQuery(), PagerFilter.getUnlimitedFilter())
issues = searchResult.getResults().collect {issueManager.getIssueObject(it.id)}
} else {
log.error("Invalid JQL: " + jqlSearch);
Rob B
February 27, 2020
Hi Payne, thanks so much for you help.
Im getting the below error when i put this into my condition....
Message:
groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.search.SearchResults.getResults() is applicable for argument types: () values: []
Possible solutions: getIssues()
Payne
February 27, 2020
You must be running an older version of Jira than we are (8.5); getIssues() was replaced with getResults() somewhere along the way. My script is an updated version of one that I found at https://community.atlassian.com/t5/Marketplace-Apps-Integrations/How-to-run-JQL-query-inside-Groovy-script/qaq-p/194691 Try that one and see if it works for you.
Rob B
February 27, 2020
Excellent! Thanks again for your help
Rob B
February 27, 2020
Can i ask is it possible to get a results of true or false rather than issues? Thanks
Payne
February 27, 2020
Sure; you can conclude with a line like this:
return issues.size() > 0
Rob B
February 28, 2020
Thanks Payne, but for some reason im not getting the correct result. My JQL is correct when i run that but in this condition its not working it thinks its true. But if i misspell a status it does what its meant to and comes out false. Hope that sort of makes sense?
Payne
February 28, 2020
If it's returning true, then the List must contain one or more issues. Remove the new line (return issues.size() > 0) and see which issues are being returned. You may need to refine your JQL.
Payne
February 26, 2020
You can use status was "Some Status"
Rob B
February 27, 2020
Hi Payne, sorry im confused what you mean?
Im looking for a script just like the JQL
status changed FROM "Status 1" TO "Status 2"
Payne
February 27, 2020
Sorry, I thought you were seeking the JQL. I'm attaching a script as a new answer.
