Care to explain in a bit more detail what you would like to do?
Jira Cloud is already hosted in AWS.
Might be me but still gonna need more information than that. If you have a certain use case, feel free to write it out a bit more.
We have Jira cloud instance and AWS Server, How we can hit AWS server with JIRA instance.
We need to hit AWS server through Jira
Can we connect +91 9966665664
I'm sorry, but repeating the statement we are questioning does not help.
Try explaining what you mean by "hit" for a start. What is your Jira doing when it "hits" AWS?
You will need to set up shared authentication between Jira and AWS (probably by tokens you can use in the webhooks), but we can't help you with that without knowing how you are doing users in your Jira, or how you are doing users or remote access to your AWS systems.
