I am trying to activate jira and confluence to be able to access through HTTPS, I followed the steps indicated in https://confluence.atlassian.com/adminjiraserver073/integrating-jira-with-apache-using-ssl-861253896.html but it does not work and when accessing Jira it gives error. Could you please help me?
Thank you
Hi @itpeopleperformance ,
Sure, Community is ready to help you.
However, you need to share the configuration details and error message you are noticing.
Kiran.
I have this in my server.xml file
<Connector acceptCount="100"
connectionTimeout="20000"
disableUploadTimeout="true"
enableLookups="false"
maxHttpHeaderSize="8192"
maxThreads="150"
minSpareThreads="25"
port="8080"
protocol="HTTP/1.1"
redirectPort="8443"
useBodyEncodingForURI="true"
scheme="https"
proxyName="mypage.com"
proxyPort="443"/>
maxThreads="150"
port="8081"
protocol="HTTP/1.1"
redirectPort="8443"
useBodyEncodingForURI="true"/>
This is my httpd.conf file
<VirtualHost *:80>
# JIRA Proxy Configuration:
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
SSLProxyEngine On
ProxyRequests Off
ProxyPreserveHost On
ProxyPass /jira http://myweb.com:8080/jira
ProxyPassReverse /jira http://myweb.com:8080/jira
SSLCertificateFile /etc/ssl/certs/myweb.com.crt
SSLCertificateKeyFile /etc/pki/tls/private/myweb.com.key
SSLCertificateChainFile /etc/pki/tls/certs/myweb.com.bundle
</VirtualHost>
This is the error:
Try including this in server.xml
secure="true"
In httpd conf include the below entry and then restart apache and JIRA
RewriteEngine On
RewriteCond %{HTTP} off
RewriteRule (.*) http://%{HTTP_HOST}%{REQUEST_URI}
Kiran
