Having trouble creating multiple issues using rest api call (bulk)
Tony Pham
When I am trying to use the bulk rest api to create multiple issues, I am keep getting the following error:
["Unexpected character ('{' (code 123)): was expecting double-quote to start field name
Here is my data file:
"issueUpdates":
"update": {},
"fields":
"project":
"key": "SIT"
"issuetype":
"name": "Task"
"summary": "Authentication error while logging into C1PA-SAPWS-V03",
"description": "Authentication error while logging into C1PA-SAPWS-V03",
"priority":
"name": "Priority 1"
"customfield_10400": "INC0154144",
"customfield_10804": "ICB-Server Ops",
"customfield_10800": "apps",
"customfield_10801": "capture",
"customfield_10803": "Direct input",
"customfield_10900": "Work in Progress"
"update": {},
"fields":
"project":
"key": "SIT"
"issuetype":
"name": "Task"
"summary": "PROJECT -- Move node IL76 to new office space",
"description": "PROJECT -- Move node IL76 to new office space",
"priority":
"name": "Priority 2"
"customfield_10400": "INC0154145",
"customfield_10804": "ICB-Network",
"customfield_10800": "network",
"customfield_10801": "jutnet",
"customfield_10900": "Pending"
Matthias Gaiser _K15t_
Hi @Tony Pham,
in general I'd recommend to ask these questions in the developer community.
However comparing your JSON to the one documented in the REST API docs, you have a pair of curly brackets too much. You have to get rid of the curly bracket before "field" - and also the corresponding closing bracket. So your JSON would look like this:
"issueUpdates": [
"update": {},
"fields": {
"project": {
"key": "SIT"
"issuetype": {
"name": "Task"
"priority": {
"update": {},
"fields": {
"project": {
"key": "SIT"
"issuetype": {
"name": "Task"
"priority": {
Matthias.
Tony Pham
Thanks Matthias, it is working now...
Like Matthias Gaiser _K15t_ likes this
