Which filter to apply, to find the date when a label was added to a JIRA?
There is not filter like this.
Anyway I can find the date when any component was added/modified? E.g. I have edited a JIRA and changed the 'country enabled' from 'No' to 'Yes' in the dropdown.
Or
Can we add filter based on history log?
You can not filter issue on history log.
You can use an add-on to develop your own JQL function like Power Scripts or Scriptrunner.
If you want to use the Power Scripts add-on, you can read this documentation:
