dependencies from maven repo for Gradle:
wildfly version : wildfly-10.0.0.Final
ERROR [org.jboss.resteasy.resteasy_jaxrs.i18n] (default task-60) RESTEASY002010: Failed to execute: javax.ws.rs.NotFoundException: RESTEASY003210: Could not find resource for full path: http://localhost/xyz/xyz/xyz
at org.jboss.resteasy.core.registry.ClassNode.match(ClassNode.java:75)
at org.jboss.resteasy.core.registry.RootClassNode.match(RootClassNode.java:48)
at org.jboss.resteasy.core.ResourceMethodRegistry.getResourceInvoker(ResourceMethodRegistry.java:445)
at org.jboss.resteasy.core.SynchronousDispatcher.getInvoker(SynchronousDispatcher.java:257)
at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:194)
at org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:221)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:51)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:85)
at io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131)
at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
at io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
at io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
at io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:284)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:263)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:174)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:202)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:793)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Hi Tarun,
Have you looked at the below discussion. The dependencies mentioned in Joe Clark's post works fine for me.
https://community.atlassian.com/t5/Jira-questions/JIRA-REST-client-simple-example/qaq-p/464118
can u provide gradle dependencies which will compatible with wildfly10 ?
Hi Tarun,
I am not a gradle or wildfly10 user. However, you can see the equivalent gradle dependency in the maven repository link under the gradle tab:
You may also find this useful:
Muaamar
Thanks Muaamar,
yeah i tried this. It is working fine alone but not compatible with my application which is running on wildfly 10 . and it is raising error on resteasy and undertow which is present with wildfly10.Is there internal dependency with resteasy or any other which will affect resteasy?
i tired almost all versions of jira-rest-java-client ,jira-rest-java-client-core and jira-rest-api.All are causing same issue.
if you know help me.
