I have successfully created an issue however if I want to attach a file to an existing issue I cannot do so using VBA.
I have successfully been able to add a file using the "curl" example here: https://docs.atlassian.com/jira/REST/latest/#api/2/issue/{issueIdOrKey}/attachments-addAttachment as per the example:
"curl -D- -u admin:admin -X POST -H "X-Atlassian-Token: no-check" -F "file=@myfile.txt" http://myhost/rest/api/2/issue/TEST-123/attachments"
It was quite easy using "curl" however I need to do it using Microsoft VB.
I get an error "FileUploadException: the request was rejected because no multipart boundary was found
Now I am new to this and know nothing about what is meant by "multipart boundary" means and I assume "curl" does some of this magic internally?
Any assistance would be greatly appreciated, here is my sample code:
Sub JIRA_PostAttachment()
Dim oHttp As Object
Set oHttp = CreateObject("Microsoft.XMLHTTP")
' initialize variables that we will set and pass as parameters
Dim pHtml As String
Dim strResponse As String
pHtml = "https://jira.ae.sda.corp.test.com/rest/api/2/issue/IS-163/attachments"
'-- prepare the HTTP POST message
Call oHttp.Open("POST", pHtml, False)
' Set headers
oHttp.SetRequestHeader "X-Atlassian-Token", "nocheck"
oHttp.SetRequestHeader "Content-Type", "multipart/form-data"
oHttp.SetRequestHeader "Authorization", "Basic Yzc3NjQ2OTpHaWxpdDIwMTY/"
'-- send the message
Call oHttp.Send("file=C:\Users\c776469\FORM1.msg")
strResponse = oHttp.ResponseText
MsgBox strResponse
Set oHttp = Nothing
End Sub
You can use this VBA code:
Private
Sub
Test()
Dim
oJiraService
As
MSXML2.XMLHTTP60
Const
STR_BOUNDARY
As
String
"abc123-xyz123"
Dim
sUrl
As
String
, sRest
As
String
, sIssueNumber
As
String
Dim
sFileDataStr
As
String
, sPath
As
String
, sStatus
As
String
Set
oJiraService =
New
MSXML2.XMLHTTP60
sIssueNumber =
"AMC-7861"
sPath =
"C:\Temp\test1.txt"
sFileDataStr =
& STR_BOUNDARY & vbCrLf & _
"Content-Disposition: form-data; name="
"file"
";Filename = "
& Mid$(sPath, InStrRev(sPath,
"\") + 1) & "
" & vbCrLf & _
"Content-Type: application/octet-stream"
& vbCrLf & _
vbCrLf & GetFileBytes(sPath) & vbCrLf &
& _
STR_BOUNDARY &
With
oJiraService
.Open
"POST"
, sUrl &
"rest/api/2/issue/"
& sIssueNumber &
"/attachments"
False
.setRequestHeader
"X-Atlassian-Token"
"nocheck"
.setRequestHeader
"Content-Type"
"multipart/form-data; boundary="
& STR_BOUNDARY
.setRequestHeader
"Authorization"
"Basic "
& EncodeBase64(
"theuser"
"mypassword"
.send stringToByteArray(sFileDataStr)
'.send sData
sRest = .responseText
sStatus = .Status &
& .statusText
End
With
Set
oJiraService =
Nothing
end sub
Public
Function
EncodeBase64(text
As
String
As
String
Dim
arrData()
As
Byte
arrData = StrConv(text, vbFromUnicode)
Dim
objXML
As
MSXML2.DOMDocument
Dim
objNode
As
MSXML2.IXMLDOMElement
Set
objXML =
New
MSXML2.DOMDocument
Set
objNode = objXML.createElement(
"b64"
objNode.DataType =
"bin.base64"
objNode.nodeTypedValue = arrData
EncodeBase64 = objNode.text
Set
objNode =
Nothing
Set
objXML =
Nothing
End
Function
Public
Function
GetFileBytes(
ByVal
fPath
As
String
As
String
Fnum = FreeFile
Dim
bytRtnVal()
As
Byte
If
LenB(Dir(fPath))
Then
''// Does file exist?
Open fPath
For
Binary Access Read
As
Fnum
ReDim
bytRtnVal(LOF(Fnum) - 1&)
As
Byte
Get
Fnum, , bytRtnVal
Close Fnum
Else
Err.Raise 53
End
If
GetFileBytes = byteArrayToString(bytRtnVal)
Erase
bytRtnVal
End
Function
Public
Function
byteArrayToString(bytArray()
As
Byte
As
String
Dim
sAns
As
String
sAns = StrConv(bytArray, vbUnicode)
byteArrayToString = sAns
End
Function
Public
Function
stringToByteArray(srcTxt
As
String
As
Byte
stringToByteArray = StrConv(srcTxt, vbFromUnicode)
End
Function
Thanks, this appears to be the code I ended up using, Found it or something really close to it online. Is there a way I can include a comment in the POST?
Hi @Joe Gigliotti,
I have done the same in C#. Hope the below snippet helps:
private static Boolean PostMultiPart(string restUrl, string filePath) { HttpWebResponse response = null; HttpWebRequest request = null; try { var boundary = string.Format("----------{0:N}", Guid.NewGuid()); var content = new MemoryStream(); var writer = new StreamWriter(content); FileInfo file = new FileInfo(filePath); var fs = new FileStream(file.FullName, FileMode.Open, FileAccess.Read); var data = new byte[fs.Length]; fs.Read(data, 0, data.Length); fs.Close(); writer.WriteLine("--{0}", boundary); writer.WriteLine("Content-Disposition: form-data; name=\"file\"; filename=\"{0}\"", file.Name); writer.WriteLine("Content-Type: application/octet-stream"); writer.WriteLine(); writer.Flush(); content.Write(data, 0, data.Length); writer.WriteLine(); writer.WriteLine("--" + boundary + "--"); writer.Flush(); content.Seek(0, SeekOrigin.Begin); request = WebRequest.Create(restUrl) as HttpWebRequest; if (request == null) { return false; } String username = "npts.integration"; String password = "integration.npts"; String encoded = System.Convert.ToBase64String(System.Text.Encoding.GetEncoding("ISO-8859-1").GetBytes(username + ":" + password)); request.Method = "POST"; request.ContentType = string.Format("multipart/form-data; boundary={0}", boundary); request.Accept = "application/json"; request.Headers.Add("Authorization", "Basic " + encoded); request.Headers.Add("X-Atlassian-Token", "nocheck"); request.ContentLength = content.Length; using (Stream requestStream = request.GetRequestStream()) { content.WriteTo(requestStream); requestStream.Close(); } using (response = request.GetResponse() as HttpWebResponse) { if (response.StatusCode != HttpStatusCode.OK) { var reader = new StreamReader(response.GetResponseStream()); return false; } return true; } } catch (WebException wex) { if (wex.Response != null) { using (var errorResponse = (HttpWebResponse)wex.Response) { var reader = new StreamReader(errorResponse.GetResponseStream()); } } if (request != null) { request.Abort(); } return false; } finally { if (response != null) { response.Close(); } } }
Thanks, this is very similar to the VBA code I finally found. I have that working now.
The multipart boundary is a string which signifies the boundary between different parts of the multipart request - this tells the server how to read the request. More information can be found here.
Now you are clearly missing the boundary definition in the Content-Type header - you need to add that. You also need to add the actual boundary before sending the file. I'm not quite sure how this is done in VBA, but there are some questions on Stack Overflow that might help you.
Thanks for the tip. I found an article that demonstrates this in VBA and now have it working. My new problem is adding a comment to the attachment each time I load it. I suspect I need to use json or xml to accomplish this, but would prefer another method. Curl can do this, but I am working to avoid curl.
Hi Jeff,
Could you please share the working VBA code to add attachments. please share.
Thanks Peter, I read the references you provided about the "multipart request" however I am still struggling with this.
What changes have you made to the code above and what is returned by the server? Did you follow the answer from the stack overflow question? There is a blog post with a VB6 function which does exactly what you need - https://wqweto.wordpress.com/2011/07/12/vb6-using-wininet-to-post-binary-file/.
Add a reference to Microsoft XML, v6.0 and use:
Private
Sub
Test()
Dim
oJiraService
As
MSXML2.ServerXMLHTTP60
Const
STR_BOUNDARY
As
String
"abc123-xyz123"
Dim
sUrl
As
String
, sRest
As
String
, sIssueNumber
As
String
Dim
sFileDataStr
As
String
, sPath
As
String
, sStatus
As
String
Set
oJiraService =
New
sIssueNumber =
"AMC-7861"
sPath =
"C:\Temp\test1.txt"
sFileDataStr =
"file"
";Filename = "
"\") + 1) & "
" & vbCrLf & _
& vbCrLf & _
& _
STR_BOUNDARY &
With
oJiraService
.Open
"POST"
, sUrl &
"rest/api/2/issue/"
& sIssueNumber &
"/attachments"
False
.setRequestHeader
"X-Atlassian-Token"
"nocheck"
.setRequestHeader
"Content-Type"
& STR_BOUNDARY
.setRequestHeader
"Authorization"
"Basic "
& EncodeBase64(
"theuser"
"mypassword"
'.send sData
sStatus = .Status &
& .statusText
End
With
Set
oJiraService =
Nothing
end sub
Public
Function
EncodeBase64(text
As
String
As
String
Dim
arrData()
As
Byte
Dim
objXML
As
MSXML2.DOMDocument
Dim
objNode
As
Set
objXML =
New
MSXML2.DOMDocument
Set
"b64"
objNode.DataType =
"bin.base64"
Set
objNode =
Nothing
Set
objXML =
Nothing
End
Function
Public
Function
GetFileBytes(
ByVal
fPath
As
String
As
String
Fnum = FreeFile
Dim
bytRtnVal()
As
Byte
If
LenB(Dir(fPath))
Then
Open fPath
For
Binary Access Read
As
Fnum
ReDim
As
Byte
Get
Fnum, , bytRtnVal
Close Fnum
Else
Err.Raise 53
End
If
Erase
bytRtnVal
End
Function
Public
Function
As
Byte
As
String
Dim
sAns
As
String
End
Function
Public
Function
As
String
As
Byte
End
Function
Thanks you so much, I got it to work!
Can I ask a question please, I mostly follow the code however don't quite understand the purpose of the Functions:
GetFileBytes()
byteArrayToString()
stringToByteArray()
Glad you got it working!
GetFileBytes (uses function byteArrayToString) is reading the file from the disk as a succession of bytes (returns a string).
Once you converted your file to upload into a string you can post it to JIRA using function stringToByteArray that converts the file again into a Byte array.
I give full credit for this code to https://answers.atlassian.com/questions/286877/problems-creating-attachments-with-rest-in-asia where I initially copied it from. It is a little complicated in my opinion, you can probably get rid of both byteArrayToString and stringToByteArray that convert the file back and forth from byte array to string, etc.
Well I notice a small diference in file's size before it was sent and after that.
Any thoughts on that?
Not sure why there may be a difference. We post Excel files to JIRA since a long time using code above, no problems downloading and opening them.
You are a Hero MR2001....!!!!!
I am looking for VBA code for uploading issues to JIRA. Can anyone point me to some sample code?
Thanks in advance & best regards,
Shuba
This sample shows how to create an issue from Excel VBA to Jira
'1. Create the "Cookie"/ session
Set oJiraAuth = New MSXML2.ServerXMLHTTP60
With oJiraAuth
'.setTimeouts 50000, 50000, 50000, 50000
.Open "POST", sURL & "rest/auth/1/session", False
.setRequestHeader "Content-Type", "application/json"
.setRequestHeader "Accept", "application/json"
.Send " {""username"" : """ & JIRA_USER & """, ""password"" : """ & JIRA_PWD & """}"
sOutput = .responseText
sCookie = "JSESSIONID=" & Mid(sOutput, 42, 32) & "; Path=/Jira" '*** Extract the Session-ID
End With
If InStr(1, sOutput, "errorMessages", vbTextCompare) > 0 Then
MsgBox "Cannot connect to JIRA. Please re-enter you password and try again.", vbCritical
GoTo sub_exit
End If
Set oJiraService = New MSXML2.ServerXMLHTTP60
'create an issue - the syntax is case-sensitive
sData = "{""fields"": {""project"": {""key"": """ & sProject & """}, ""summary"": """ &
sIssueSummary & """, ""issuetype"": {""name"": """ & sISSUE_TYPE & """}}}"
With oJiraService
.Open "POST", sURL & "rest/api/2/issue/", False
.setRequestHeader "Authorization", "Basic " & EncodeBase64(JIRA_USER & ":" & JIRA_PWD)
.setRequestHeader "Set-Cookie", sCookie '*** see Create a "Cookie"
.Send sData
sStatus = .Status & " | " & .statusText
End With
MsgBox "Cannot create JIRA issue. You may not have rights to project " & sProjectFullName & vbCrLf & vbCrLf & sOutput, vbCritical
GoTo sub_exit
End If
Set oJiraService = Nothing
