Hi everyone,
I am a beginner and was hoping someone could help with an issue I have. I am trying to set a property in the workflow. The property will force the ability for only the reporter to set the state of resolution to Done for any epic transitioning to an ending status. I have an example of what I believe it is and would like some feed back. Any help would be greatly appreciated, even if it is you are doing it wrong.
Here is the example...
Property Key
jira.permission.[epic.]{permission}.{type}[.suffix]
Property Value
jira.permission.epic.done.reporter
C
Hi Christopher,
Only Problem I think is *done* in your property value as there is no such permission called Done. Check which status is mapped with Done Closed or Resolved
jira.permission.epic.close.reporter or jira.permission.epic.resolved.reporter
List of available Permission
admin, use, sysadmin, project, browse, create, edit, scheduleissue, assign, assignable, attach, resolve, close, comment, delete, work, worklogdeleteall, worklogdeleteown, worklogeditall, worklogeditown, link, sharefilters, groupsubscriptions, move, setsecurity, pickusers, viewversioncontrol, modifyreporter, viewvotersandwatchers, managewatcherlist, bulkchange, commenteditall, commenteditown, commentdeleteall, commentdeleteown, attachdeleteall, attachdeleteown,viewworkflowreadonly
Taha
Is there any workflow property which prevents linking an issue to an Epic Link ?
Regards
Abrar
The issue was resolved. Thanks for help and the permission list!
