Help with Jira assets bulk upload
James Gaiser June 24, 2025
Hello I am trying to update data from a CSV into jira assets. I have a few entries that are dates. When it does the mapping for the attribute it makes them a text type so I cant do an AQL query to search the dates in a range. How do I set it up so it recognizes it as a date at the time of upload?
Mikael Sandberg
Hi @James Gaiser,
Make sure that your date is following the expected format, MM/dd/yyyy. Have a look at this KB for more information on how to prepare your data for import to Assets.
Hello Mikael. Thank you for the welcome!
It is in that format. Should it auto detect it as a date or is there something else I need to do so it is created as a date type object?
Mikael Sandberg
Is the attribute in the Object schema defined as date?
James Gaiser June 30, 2025
Hey Mikael I was away at the end of last week. It is not. Is there a way I can configure that at time of upload? In normal jira I decide that when I create the custom field but I cant find the option to do it here.
James Gaiser July 1, 2025
Hey I got it working thank you!
Like Mikael Sandberg likes this
