Help with fixing errors in trigger.
Леонид January 27, 2025
Web Request URL:
https://123.atlassian.net/rest/api/2/issue/{{issue.key}}/worklog
The URL(https://123.atlassian.net) is correct
Request Method:
POST
Web request body:
{ "timeSpent": "1d", "comment": "Automatically adding time at 17:00", "started": "{{now}}" }
Content-Type header: application/json
Authorization header: (Basic ...)Снимок экрана 2025-01-27 143858.jpgСнимок экрана 2025-01-27 143935.jpg
When starting, it writes errors in the log:
2 accepted
Bill Sheboy
January 27, 2025
Hi @Лёня Криволапов -- Welcome to the Atlassian Community!
The rule you show has
  • a Scheduled Trigger (likely without any JQL)
  • a Lookup Issues action
  • a Send Web Request, trying to reference {{issue.key}}
But there is no issue available to use, only the results of the lookup, and so the URL for the request does not work.
And...the reason you cannot see the Log Work action is the same reason: it is currently displaying the Compatible actions, and without an issue that is not compatible.
There are two ways to solve this:
  1. remove the Lookup Issues action and add the JQL to the trigger, using the Log Work action to add the time
  2. remove the Lookup Issue action and add the JQL to a Branch on JQL, using the Log Work action
Thank you very much for your help.
Like Bill Sheboy likes this
Tuncay Senturk
Hi @Лёня Криволапов
Your configuration seem fine at first glance. Is there a reason you don't use the Log Work action instead of making a web request?
I'm just learning automation in Jira.
I was recommended Log Work but I just can't find it.
Tuncay Senturk
I see. Is Time Tracking enabled for the project? If this feature is disabled, you may not be able to see the option to log work.
