Hi, Can we connect Jira with MS Project?
Pramodya Gamaethige
I need to link my jira projects with MS Project. Is it possible?
Sergey Gussak
June 9, 2021
You can use Ceptah Bridge: https://www.ceptah.com. It can synchronise most JIRA fields as well as Tempo. It has been around for 10+ years and caters for most real-life scenarios.
Pramodya Gamaethige
Thanks for the suggestion @Sergey Gussak
Daniel Ebers
June 5, 2021
Hi @Pramodya Gamaethige
for a rather specialized App like this one it will be unlikely you will meet somebody here in Community just in the moment you need a thorough answer - that would be of a great coincidence.
If your ask would have been to a very common App with thousands of customers it would be a different story.
Basically you are left with two common options:
  • test if the App does what it should do for you, give it a test for a few days (in this case, you need to contact the Vendor a marketplace message tells me)
  • ask the vendor if they offer a screenshare/webinar/Q&A session - scheduled or just for you.
    In this case - as Marketplace refers to them anyway, I'd encourage you to just ask
    • Ask them also everything that is still unclear and/or if you have feature requests in mind.
Daniel
Pramodya Gamaethige
Hi Daniel thanks for the suggestion. appreciate it.
Jack Brickey
No this is not possible at least based on my experience and understanding. What exactly is your goal here?
Pramodya Gamaethige
I need to extract Jira Projects to MS Projects to create some project level dashboards with additional columns.
Pramodya Gamaethige
https://marketplace.atlassian.com/apps/9203/ceptah-bridge-jira-ms-project-plugin?hosting=cloud&tab=overview
There are couple of plugins when i search in google. But dont know whether it works or not
