Hi, I am not not able to create jira issues in jira server using jira-create-issue node in node red
Shreekanth B June 16, 2019
Shreekanth B June 17, 2019
image.pngI have access to server.
Andrew
June 17, 2019
You marked 'answer accepted'. Are You need help or answer resolved your issue?
B.R.
Like Shreekanth B likes this
Yeah, I need help. Please help me out.
Andrew
June 17, 2019
If You need help, please, unmark 'accepted' it is confused other users. They may not help because think that issue resolved.
Node-red run from Your station or from remote server? I mean if node-red running on server A and Jira placed in server B You need check port connection from A -> B.
B.R.
Both are running on same server.
Andrew
June 18, 2019
Andrew
June 17, 2019
Hi @Shreekanth B ,
How I see error is 'connection refused'.
  1. Nothing is listening on the IP:Port you are trying to connect to.
  2. The port is blocked by a firewall.
Could You please check have you access to server, try open in browser some like as /rest/api/2/project ?
B.R.
