Hi , Is there another way to add checkbox to jira administration? .
Hanan Golfeigen June 7, 2022
I can choose it from configuration board ,but it is not appeared in the list board
it is only in details when drilled down the task and shown in columnsScreenshot 2022-06-08 0930329.jpg
Lucas Modzelewski _Lumo_
Hi @Hanan Golfeigen ,
welcome to the Atlassian community :)
If it's supposed to be yes/no answer, then you can use dropdowns which will make sure only 1 option is selected
Hanan Golfeigen June 15, 2022
Thank you very much , that exactly the way i did it
