Hi Team, I need custom field ID for column 'Fix Version/s'.
Business Reports
December 11, 2019
I need custom field ID for column 'Fix Version/s' to get the value of Fix Version/s corresponding to the issue key.
Can someone help me to get the custom field ID for Fix Version/s?
Sreenivasaraju P
December 11, 2019
Hi @Business Reports ,
Fix version/s is not Custom field. It is a system field. System fields doesn't have any ID.
Adam Rypel _MoroSystems_
System fields do have ID, for Fix Version/s it is "fixVersions".
You can always find the field IDs by GET endpoint "{baseUrl}/rest/api/2/issue/{issueIdOrKey}"
Pete Singleton
December 12, 2019
As above, Fix Version is not a Custom Field.
Are you using the REST API?  If so you can retrieve all versions for a project with /rest/api/3/project/{projectIdOrKey}/versions
If not using REST API, what are you trying to do?
Matias Bolyos October 27, 2023
Hi!
I´m trying to execute this endpoint:
XY.atlassian.net/rest/api/3/field/search?id=versions
But instead, I´m getting all fields.
