Remove double scrollbar in issue full view
Sarah Green
I was trying to test out the keyboard shortcuts and I accidentally enabled a second scrollbar while in the full issue view.  How can I turn this off?
Ste Wright
Hi @Sarah Green
The right-hand side is part of the main issue view - it's split into description fields on the left - i.e multi-line text fields - and context fields on the right, which is pretty much everything else.
Not sure why you have two scroll bars though - is this just happening for you or all users on your instance? If it is just you - I'd check your computer hasn't had any modifications to screen resolution or monitor sizing, etc first.
If none of this has been modified - what browser are you using? Have any browser settings been changed around sizing?
Ste
Sarah Green
Ah that's what it was! I knew something was different - it was the added scrollbar. (I edited my post for clarity based on this.)
I was messing around with the keyboard shortcuts as a I said, and it somehow enabled it. I don't remember which one it was.
I don't believe it has anything to do with computer mods or my browser since it happens while I was testing shortcuts.
Ste Wright
Hi @Sarah Green
There is no option to toggle a second scroll-bar / slice up the screen like this, as far as I know!
Keyboard shortcuts can have impacts on browser settings as well as Jira - often there is some crossover between them.
I would try:
  • Accessing this URL from a different browser and/or...
  • Accessing from a different computer
It'll help clarify the if the issue is Jira based (related to your user settings) or browser/computer based.
You could also try simply closing your browser session and logging out/in again - there are a range of settings which reset to default when a login session ends - if this is an anomaly, it might disappear with this action :)
Ste
Carsten Gehling
August 18, 2020
This has suddenly popped up on my issue-view today as well.  Using Google Chrome Version 84.0.4147.125 (Official Build) (32-bit) - I have made no changes since before this happened, as far as I am aware.
Ricardo_Zamora October 16, 2020
Hi @Ste Wright
I too am having this issue.  I have not changed any settings.  All of the sudden yesterday when the screen refreshed I now have two scroll bars exactly like the screen shot.  Any help you can provide is greatly appreciated.  I too am using Chrome Version 86.0.4240.75 (Official Build) (64-bit).
Ricardo_Zamora October 20, 2020
Hi @Stephen Wright _Elabor8_  Any guidance on this issue?  Thank you!
Ste Wright
Hi @Ricardo_Zamora
I would contact https://support.atlassian.com/ in this instance :)
This is because it doesn't happen for everyone so might be site-specific!
Ste
@Sarah Green
Hi!  How did you solve this issue?  I still have the two scroll bars too.  Thank you.
Sarah Green
It went away for me after one of the recent updates.
Like Ricardo_Zamora likes this
Moorthy Muniyandi
November 9, 2020
A recent update for what? chrome version or Jira version
Sarah Green
Jira version I believe
