Hi there!
I have a project in JIRA with one project lead and several managers in it. I need to configure scheme where:
— nobody of them will see other projects / issues / users etc
— project lead will be the only assignable user
— managers will see only theirs issues in this project (e.g. I am manager1, and I don't see issues created by manager2)
I've read lots of stuff about permissions / issue security scheme but still it's not working.
Requesting your help, thanks :)
It depends on your other project permissions. If admins in other project would add a group or individual user to the project they would see it. You do not have much control on that.
There is a permission Assignable User so you need to modify your Permission Scheme and add only Project Lead to this permission
This is done via Security Levels. You need to define a default security level that would include Reporter (or a user fields that define Managers if someone is filling the ticket not managers)
If I am a manager and I create a ticket (that should be only visible to me) then I become the Creator/Reporter of this issue. So if you define a default Security Level called for example "Restricted" and add only Reporter to it then people would only see what they created until the Reporter would change or Security Level of this specific issue..
HI @ML888
I would suggest the following steps for your requirement.
1.Set the roles on who to access the project
2.Set the browse project permission to those Project roles only
eg:
Add the users to Admin role to those who need to access Project admin part
Add the users to user role to those who need to have access only to work with issues not the project admin part(Create a user role to provide basic project permissions)
1.Set default assignee has project lead
Project setting->users and roles->Edit default->default assignee to project-lead
2.Go to permission scheme->set Browse project and Assign Issues to the project lead
Set a Issue security scheme which is restricted only to reporter (if only managers use to create issues)
Or
1.Create a user picker field
2.Set a Issue security scheme which is restricted only to the user picker field(if any one can created issue but only respective mangers should view the issue)
Can use the field(user picker)to choose the manager name.
Note:
To get all this work the basic permission could be "Browse project" and "Create Issue(in 1st and 2nd case)"
Kavishree K
I think below answers will suit your requirement
-->If you don't want others to see your projects / issues . you can restrict the Browser project permission to Project roles .. so who has project permission can see the project.
--If project lead want to have only assignable permission then project lead should have assignable user permission ,&browse project and you can remove project lead from other permissions. If any security level is applied to the issues he cannot see .
-->you can use issue security scheme and set the security level only to reporter. so if they select this security level only reporters can see the issues others cannot .
The main point is about hiding issues which were created by another manager from other managers. I know how resolve #1 & #2 from my list
