Hide right panel in issue view
Jason Burdey
Is it possible to hide and/or shrink the right panel when viewing an issue in issue view? Sometimes I just want to focus on the description and the issue but the right panel is taking up alot of room (1/3 of the page width)
3 votes
Liron
May 10, 2022
Hi all,
We just released the ability to resize the right hand sidebar in the new issue view.
Hope this solves the problem!
Liron
Andrew Tolley
May 10, 2022
Great - thank you!
Like Arshiya Sultana likes this
An Vo Nguyen Tam
May 10, 2022
Cool, it's much better now <3
rgi_manning
May 11, 2022
Agreed!   Thank you very much!  This is a great improvement.
Nancy Mooney
Thank you.
Bell Witkowski
Would it be possible to also add expand/collapse to the right hand panel in the future? The resize is great but my personal preference is to use expand or collapse maximizing my total screen area when I write. Thank you in advance for your work.
Like # people like this
Liron
July 6, 2022
yes I have opened a JAC ticket for this. We will be exploring that in the future.
Thanks all!
https://jira.atlassian.com/browse/JRACLOUD-79327
Kalpesh Panchal
September 21, 2022
The right hand pane information is not relevant while working on the issue where you need the full real estate of the page to put in your content.  It is just in the way.
I am constantly scrolling left and right to see the content I put in.
Normally on a high resolution monitor this would be ok, on a laptop, there is a little screaming involved.
It should be collapse-able.
Tom Buttner
December 2, 2022
This change isn't visible to me on 8.20.11. What version of Jira do I need to ask my IT team to update to to pick up this change?
Liron
December 8, 2022
@Tom Buttner - apologies for not being clearer - this change was rolled out in Cloud.
Boris Bayle
March 19, 2024
Same for me. please add collapse/uncollapse for the right panel.
I kill my eyes with this right panel I dont need when editing the description..
20 votes
Nancy Mooney
I second the motion on hiding the right panel. It is massive and not necessary to view all the time. It makes the main center panel much too limited (sorry this is not an answer - just hoping Atlassian takes notice).
Dean Capp
Yes, what a travesty of design! What were people thinking - were they thinking? and did they even test this???
rgi_manning
March 4, 2022
Just started using JIRA Cloud, and that panel has got to go... using up way too much real estate!
Ingrid Sluimer
July 29, 2024
Company just switched to cloud and I'm unpleasantly surprised.
Why on earth would anyone need a sidebar with issue details in an issue-detail view?
But I'm not very hopeful, looking at the age of this thread.
Workarounds don't seem to work for me, we're pretty locked down in the browsers here.
Laetitia De Boissieu
March 20, 2025
The resizing of right panel helps but it's not enough. It would be really better to hide or show the right panel completely on demand.
11 votes
quang.huynh
January 14, 2022
For those who're still finding this, here is my solution:
Add a bookmark in your browser, let's say it "Toogle"
In the address, enter this
javascript&colon;jQuery("[data-test-id='issue.views.issue-details.issue-layout.right-most-column']").parent().toggle();
Replace "&colon;" with ":" without quotes.
Now when you open a ticket, click on it to show/hide panel as needed
Toni Jordà
January 14, 2022
Thanks, Quang, it works fine!
lana.went January 19, 2022
Hey Quang - were you able to do this on Chrome recently? My Chrome won't seem to allow me to add such snippets as bookmarks - it expects valid URLs?
quang.huynh
January 19, 2022
Replace the part "&colon;" with ":" (without the quotes) so it looks like this
OMG Quang - it worked - you've just dramatically improved my life - THANK YOU!!! :D
Like quang.huynh likes this
An Vo Nguyen Tam
April 18, 2022
gosh you're a genius :)))) can't say how much I love this >.<
Jeffrey Simon
November 24, 2022
What a great workaround! Perfect!
Deanna_Mirra
April 3, 2023
Thank you patron saint of Jira, Quang!!
Colin Starker August 7, 2024
This fix is no longer working.
Dirk Loeckx October 8, 2024
The following code seems to work (you still have to replace the &colon; with a real colon:):
javascript&colon;(function(){el=jQuery("[data-testid='issue.views.issue-details.issue-layout.container-right']")[0];el.style.display="none";})()
Note that it no longer toggles, but just removes the sidebar.
PS: This can be extended to remove other parts of the view. As I wanted to use it to print JIRA issues a little bit nicer, I've created a bookmarklet with the following code (prepend it with 'javascript&colon;' to make it a bookmarklet):
(function(){
let queries = [
"[data-testid='ContextualNavigation']",
"[data-testid='issue.views.issue-details.issue-layout.container-right']",
"[data-component-selector='jira-issue-view-common-component-resize-handle']",
"[id='ak-jira-navigation']"
for (let i = 0; i < queries.length; i++) {
el = jQuery(queries[i])[0];
el.style.display = "none";
window.print();
Like Deanna_Mirra likes this
6 votes
Stijn Beeckmans
Matt Lavis
February 24, 2021
Stijn, you are a star. This had been pretty much unusable.
Zack Morris
Wow that's really cool! I've tried to reply to this eleventeen times, but there's a bug in this forum that replaces javascript colon with &colon; so there's no way for me to paste the code verbatim, even in a code block:
javascript&colon;
And I can't reply to the linked issue, so here's a slight modification that also sets the css max-width to 25% to take up less space while shown, and I've included a second one that only changes the max-width but doesn't toggle visibility:
https://snippi.com/s/6nqpmo9
Just select one of the snippets and drag it over your browser's bookmarks bar at the top of the window (you may need to click Chrome->View->Always Show Bookmarks Bar).
Then you can right-click the bookmark, edit its URL, and change '25' to your desired percentage.
There's a bit of errata around this due to the unfortunate decision 25 years ago to use % to url encode characters in the browser, so:
e.style.maxWidth='25'+String.fromCharCode(37);
means '25' + '%' and is necessary for the bookmarklet to work in Safari. Other strings like '200px' just work without the +String.fromCharCode(37) portion.
I'm still looking for a way to run the bookmarklet automatically, but I don't think it's possible without a browser extension.
Tested in Chrome, Firefox and Safari.
42Chris
May 18, 2021
ZACH YOU ARE A GENIUS... Thank you. Now I can get some sleep at night. My toggle button has arrived and it works well. Thank you saviour of the internet.. may Karma give you a wonderful life!
Like David Caldarelli likes this
Daniel Miller
Thanks, works like a charm! For any new arrivals: create the bookmark (ideally on the top bookmark bar) from one of the snippets, editing the "url" as desired for a different percentage. Navigate to a Jira ticket and then invoke the new bookmark. Your browser does not leave the JIRA ticket - instead, it imposes the Javascript fragment on the JIRA ticket, reducing or hiding the right panel.
Nancy Mooney
This is a thing of beauty. Already shared with coworkers. Thank you Zack!
But seriously JIRA - fix this!
ysabelle.torres
May 23, 2021
Thank you so much, Zack! What a saviour :)
Andrew Tolley
June 17, 2021
Just another grateful user - so much better to be able to hide the panel so I can focus on the important stuff!
Antonio García
It's incredible that users have to figure out solutions on their own instead of Atlassian providing them.
Just terrible.
Toni Jordà
July 5, 2021
Great contribution, Zack
Thanks a lot!
4 votes
Paul Benson
March 30, 2021
Yeah I really wish this was a feature in JIRA. I absolutely hate the right-hand panel because I can't shrink it. I just wish it operated like the left-hand panel with an arrow so I could collapse it or uncollapse it at-will.
Marcelo Lourenço
I created an extension to collapse/expand the right panel of Jira. Freeing up more space on the main panel. It will be useful until they implement this function in Jira.
https://chromewebstore.google.com/detail/occanfpdiglllenbekgbnhijeoincilf
Daniel Miller
Very disappointing and surprising. Just about every modern UI with sidebars gives the user some control over their display and sizing. Was this a purposeful "we know better than you the right way for you to work" decision, or an oversight?
pvm30
February 17, 2021
Almost impossible to use this the way it is right now, even more difficult if you have a small screen.
I don't want to have 40% percent of my view width completely squandered by something I don't need at all.
Having a button to hide this shouldn't be so hard.
Forcing everybody to have to deal with this kind of "mobile first" point of view sucks ...
Dean Capp
Why is this company worth so much again?
Stijn Beeckmans
Does anyone know of a ticket to change the width of (or hide) righthand sidebar?
I found in their CSS that they have set the width of this panel to 40%...
Changing the CSS of the .hvyTRk CSS class to
width: 10%;
padding-right: 0
in Chrome dev tools shows a much better layout...
Shouldn't be that hard to fix @[deleted]...
Mikael Sandberg
The short answer is no, you cannot hide the right panel. I saw in another thread that Atlassian is working on changing the view a bit, but not sure if that includes being able to hide/change the size of the panels.
Shashank_Mulay October 22, 2020
I too struggling. I need bigger description space. Right panel is not needed all the time. It is covering my half of the page.
Like Mike Buscemi likes this
Prashant Tajne February 15, 2021
Ya...the description needs more space..
Lincoln Yesire September 30, 2024
I create an extension to hide/show the right hand sidebar(or called panel),maxmize the create issue dialog.You can toggle the status of right hand sidebar or create issue dialog by clicking the extension icon in corresponding view. In addition, the default keyboard shortcurt is CTRL+B (you can set the shortcut as your willing by extension manager).
chrome: Better Jira Browse - Chrome Web Store (google.com)
edge: Better Jira Browse - Microsoft Edge Addons
I define "Better Jira Browse Status" as "the right hand sidebar/panel was hidden" and "the create issue pop up dialog/window maxmized", and the "not Better Jira Browse Status" as the opposite. Correspondly The icon with check mark of the extension stands for the "Better Jira Browse Status", The icon without check mark of the extension stands for the "not Better Jira Browse Status". The "Better Jira Browse Status" is on by default when extension is installed and will keep until you click to toggle it again. For convience, you could pin the extension so that you can click icon to toggle status easily, or of course you can use the keyboard shortcut.
Contact with me if you have any problem when you use the extension.
Mary Van Nostern
Please move https://jira.atlassian.com/browse/JSWCLOUD-21242 from Gathering Interest to Backlog.  There is plenty of interest ^^^^^ to be able to configure this OOTB for ease of usability.   Thank you! and my team of 800+++ thanks you!!
Dean Capp
Tx Zack!!! Atlassian, why couldn't you do this????
Zack Morris
A temporary solution is to create a browser stylesheet (I put mine in my home user folder ~/stylesheet-overrides.css) containing:
body > div.atlaskit-portal-container .hJPObX {
max-width: 300px;
#jira-frontend .hxewZo {
max-width: 200px;
body > div.atlaskit-portal-container .sc-jhAzac:last-child, body > div.atlaskit-portal-container .dbCBBb:last-child, body > div.atlaskit-portal-container .hJPObX {
max-width: 300px;
#jira-frontend .sc-jhAzac:last-child, #jira-frontend .dbCBBb:last-child, #jira-frontend .hxewZo {
max-width: 200px;
Screen Shot 2021-02-04 at 4.37.05 PM.pngI don't know why the width is different in embedded mode (https://<organization>.atlassian.net/jira/software/projects/TPI/boards/4?selectedIssue=<issue>) vs zoomed (https://<organization>.atlassian.net/browse/<issue>) but at least it works.
Unfortunately this solution isn't future-proof (because the classnames may change next time Jira deploys their site) but it's easy enough to right click -> Inspect Element on the right sidebar, find the new classname(s) and update the stylesheet.
Maybe someone with better css skills can find more-permanent selectors. A few of my attempts are in the commented portion above :-)
Stijn Beeckmans
This doesn't work for me, 'cause I use the cloud version...
And class names seem to change every time i reload the page...
Shivaraju Gowda
November 4, 2020
Try disabling the "Jira labs" option in your Personal setting. This won't remove the right side information but will make it appear in the same panel as the description.
What are you talking about?
