Ho to quickly delete 40-50k issues from JIRA
Robert Strzecha
April 12, 2017
We are adding around 2k issues per day. We don't need to archive them after they are completed. At the moment we can delete them only using bulk but this action allows to remove only 1k issues. Is there any chance to remove all of them at once?
Now we are wasting time by manually deleting issues.
Appreciate your help in this request.
Josh Steckler
April 12, 2017
Hi Robert,
I found this, which may help on server but not for cloud. https://community.atlassian.com/t5/JIRA-questions/How-do-you-increase-the-bulk-change-maximum/qaq-p/417702
But if it were me, I would automate. I would write a script using the REST API that would run daily, deleting issues after a certain amount of time after closure.
Ron Gates
With ScriptRunner you can configure Escalation Service that can run periodically and remove all the issues found by defined JQL query - see the screenshot of example configuration:
jira_periodic_bulk_delete.pngAbove example will run every 60 minutes and delete all the issues found by following query:
project = "Jira" AND Status in (Closed, Resolved)
Here is the script that performs delete using "silent" deleteIssueNoEvent method which is perfect for automated bulk deletes:
def issueManager = ComponentAccessor.getIssueManager();
issueManager.deleteIssueNoEvent(issue);
I tested above approach myself and it works.
Like # people like this
GaryM November 7, 2017
It works, the issue(s) get deleted, but atlassian-jira.log contains 2-lines of ERROR message for each issue deleted. (Jira 7.5.1) (ScriptRunner 5.2.1)
2017-11-08 01:07:01,166 Caesium-1-4 ERROR admin     [c.o.s.c.jira.utils.WorkflowUtils] Errors: {}
    Error Messages: [You can not update a null issue.]
2017-11-08 01:07:01,169 Caesium-1-4 ERROR admin     [c.o.s.c.jira.utils.WorkflowUtils] Not attmpting transition
Null Issue, I guess because it deleted and nothing to transition.
Any ideas to suppress the messages?
Anja Nagel
February 11, 2021
we have exactly the same problem. The Escalation service works great, but still the messages are written to the log-file.
(Jira V8.8.1 ), (Scriptrunner 6.18.0)
Can the messages be turned off or ignored?
Martin Runge
It works perfectly and the issue(s) get deleted. Thanks josh!
aas
Does anybody know will it slow down jira if the result of JQL Query will 130K issues? May be there's some way to limit query result?
ArulAnthonySebastian Nadar July 25, 2024
Please use below code at Escalation service:
Note: If you use the Scriptrunner plugin, above code with escalation service will work.
