How I can delete a project key?
marionunes
August 8, 2016
I deleted a project and now I want to create another with the same name and I need to use the same project key, but I can't do it because JIRA say me that project key exists.
Any suggestion?
Nic Brough -Adaptavist-
August 8, 2016
You need to clear the old key out of the database.  But, it's being retained to prevent you damaging your historical data - it's only safe to clear the old key out if you have never moved issues from the deleted project out to anywhere else (or, if you have, you delete them as well)
cgadade
Hi @Nic Brough -Adaptavist- ,
   We are using Mysql database,which command will delete project key from database.?Can you please help us.
July 10, 2020
Check the table "movedissues" first.  If your project key is in there, you're going to need to do some external checks.
Yogesh Mude[Jira]
August 8, 2016
Hi @Mario Nunes
see, if you have deleted the project that time related project key also deleted.
If you want to edit the already exist project then you should be choose Edit project not delete the project.
as @Ligia Cindea mentioned above comment might be it works once you have performed Re-indexing.
Ligia Merciu
Hi, Mario
Maybe a re-index before would help.
marionunes
August 8, 2016
I did it, but doesn't work.
