How I can edit "status" work flow for next-gen project?
t4world t4world January 21, 2019
Hi everyone, I'm newbie for JiraOps and have some question as following:
1. How I can change default work flow for next-gen project?
2. I've already create my own work flow but I cannot associated with next-gen project
but only associated with classic project I can.
Many thanks for your help
Ollie Guan
Hi @t4world t4world,
You can add a new status directly on your board. Simply add a new column, and drag and drop it into the spot you want. Next-gen projects support neat, linear workflows at the moment. More workflow configuration is coming soon.
https://community.atlassian.com/t5/Next-gen-articles/Everything-you-want-to-know-about-next-gen-projects-in-Jira/ba-p/894773
Thanks Ollie Guan. As your answer, it mean that next gen project can only used default workflow for now. But, it will be more workflow configuration in the future right?
Ollie Guan
Yes, I think the extension workflow part will be added in future versions.
Thanks for your answer. Can I ask you one more question about postmortem function?
I've test postmortem function with next-gen project. I've created and modified postmortem by myself after incident was resolved.
I just want to know that it is possible to save my customise postmortem as a template, so it will useful to me to use it as a template for every incident in a project.
I tried to find knowledge base in but couldn't found the solution.
Any idea from you?
