How I can make filed required by automation rule?
{{integrationFlow. is required}}?
what are you attempting to do exactly. You don't need automation for setting a field required generally but maybe your requirements dictate otherwise? If you need automation what automation method will you use? I assume you have an addon e.g. Automation for Jira?
