Hi Kojo.
Depending on what you want to do, you may have different ways to achieve that.
The simplest may be with automation. I know that you can create a Slack integration via the action module "Send slack message".
Does it help you ?
This tutorial is for DC and Server but some information (smart values) can be used in the same way.
