Hi everyone.
How can I add additional issue status in scrum report like DONE status?
for example I have workflow:
New -> In work -> Delivery EU, Delivery GB -> Done.
In sprint report only "Done" status mark like finished issue. I want to mark like finished "Delivery" status too.
How I can do it? thanks!
Hi @RonnyBonny
Welcome to Atlassian Community !!
Sounds like you need to map "Delivery" status to the last column in the board settings. Also you may have to set the resolution when issue is moved to Delivery
hi, thank you)
nope
I mean "reports" -> "sprint reports". When sprint finished. A see list of "Completed Issues" and all issues here in status "Done".
But I want see in completed issues list task in "Delivery" status too.
Hi @RonnyBonny
That's correct by default issues in the last column of the project board in your case "Done" status are shown as "Completed" issues in reports. Reports work that way only.
If we want to show "Delivery" status issues too, please map "Delivery" status to the last column in the board settings. That's when Jira will consider as completed issues and they start appear in report as completed issues.
