I'm trying archive an issue via MyGroovy plugin and I found this code in the community:
import com.atlassian.jira.issue.archiving.ArchivedIssueService
@StandardModule
ArchivedIssueService a
def authContext = ComponentAccessor.getJiraAuthenticationContext()
//issue = ComponentAccessor.getIssueManager().getIssueObject("TESTISSUE-1234")
def validationResult = a.validateArchiveIssue(authContext.getLoggedInUser(), issue.getKey());
if (validationResult.isValid()) {
a.archiveIssue(validationResult);
But when I put this code in the Console, this error appears:
How can I fix it ?
Hi @Rafael Costa ,
that method is not more available depending on JIRA version.
Btw, try this one :
validateArchiveIssue(ApplicationUser user, String issueKey, boolean notifyUsers)
def validationResult = a.validateArchiveIssue(authContext.getLoggedInUser(), issue.getKey(), false);
So you need a boolean as last parameter of your call. More information available here
This should fixs your issue,
Fabio
Thaaanks Fabio it's still works here!
More a doubt: What means @StandardModule in this script?
Hi @Rafael Costa ,
@StandardModule is an annotation that imports ArchivedImportService module in your script.
Fabio
