I created an automation to create an Epic from a higher level Initiative type, however even though I used the is Child of link the created issue does not show in the "Child Issues" of the trigger issue. In the trigger issue I see "is Parent of" but it does not show in the Advanced Plan as a child issue. I want to set this Parent link property - how do I do it in automation?
@Ken Parry could you please share the screenshot of your automation?
@Ken Parry Instead of "linked issue - is child of", you can set Parent field:
Parent: Trigger issue.
