How can I control which column will be display in issues list under Epic / User Story ?
Ofira Daniel
For example : on Epic level see Story Point of each US (user story) inside it , on US see effort if hours for every sub task in it
somethingblue
July 6, 2017
Hi Ofira,
I may not be clear on where you're looking but if you're referring to the Issues in Epic list that is a list of the issue that are linked to the Epic.
If that is not what you're looking at please attach a screenshot and we'll go from there.
Branden
Ofira Daniel
Yes , I am referring to list of user stories in epic / list of tasks in user story .
can I add for example on the task list column to see the effort , progress ,, or other field in task ?
