I am starting a new project in Jira and would like to create a template for the stories I would create, that displays what the issue needs to have . i.e: description, acceptance criteria, IT environment, etc.
I know that in previous versions this was available, but I wasn't able to find a way to do that with the new issue´s view.
I dont see any of the details you are sharing on the top right corner. This is the only view I have.
The cog is right next to your avater (PF). Between the question mark and your green avatar :)
Hello Alex,
ah ok :)
still, I cant find there where the "issues" are. When clicking on the cog, I only get the options from the screenshot attached.
@Patricia Ferrari if you can't see the option like the image below:
Then most likely you have to contact a jira administrator to do this work for you.
Hi Alex,
Ok, that should be it. Thank you!
B/R
Patricia
Kindly mark the answer as accepted to help others in this community :)
This can be done via workflows, by adding post functions. For that to do, you need to:
Another way to create "template" issues, is to populate one issue with all the values you need, and before clicking "OK", check the "create another" option. Then hit OK. That will keep the popup open, and will be populated will all the values you've entered.
A third way is to create an automation rule which will be trigger either manually, or with another trigger of your choice.
So, if you choose something from the above, I'll be able to help you further :)
Hi @Alex Koxaras -Relational- , thank you for your very quick reply :)
I think possibly the first suggestion should be good to go as I would like to add other fields to the story. Could you help me set it up? Where do I go to create a workflow?
Patricia
Assuming that you are using the CM projects and not a TM project:
After finishing all the above and to associate your workflow with your issue type
There are a few more steps for the board, but we'll see that in the next steps.
