How can I display Atlas project data in Advanced Road Maps?
Dorothy Krajewski
September 24, 2024
We use Advanced Roadmap Plans to view quarter plans for ~50 teams, 400+ Epics.  Recently we decided to use Atlas for progress reporting on all the epics.
I'd like to view in Plans some of the Atlas data in the columns for each Epic.
  1. The synced and linked Atlas Project name
  2. Last Update Status (Pending, On Track, Off Track etc.)
  3. Last Update Date
  4. Atlas Project Owner
Atlas Target date is synced with Jira Due Date so I'm able to view this one in Plans.
Is it possible to view the others?
Walter Buggenhout
Hi @Dorothy Krajewski and welcome to the Community!
Atlas custom fields are - unfortunately - not supported to be added to a plan. You can see a list of supported custom field types in this support article and see there is no mention of them there.
Hope this helps!
heider.souza
Can we pull this data using API or maybe with an Automation from the integration?
