How can I export all jira issues?(more than 1000,or include issues that created by former employee)
韦哲 January 25, 2021
Hi,JIRA team:
Carlos Garcia Navarro
韦哲 January 27, 2021
thank you for your help,let me try~
韦哲 January 27, 2021
it works ,thank you for your help!
Prince Nyeche
January 26, 2021
Hi @韦哲
There are add-ons for this such as the Jira Cloud for Google sheets or the Jira for excel sheets. which you can download directly from Google apps or Microsoft apps.  Last resort is to use the API to download but it doesn't combine it for you which is pain. However if you can code, you can use Pandas to combine multiple csv files together.
John Funk
This is the best route to go. And it's free!
Like Prince Nyeche likes this
Pramodh M
Hi @韦哲
Backup is the feasible solution for this.
Or when you export issues, it's best to export them per project or choose the criteria you want to divide the issues.
Pramodh
韦哲 January 27, 2021
thank you for your help:)
KAGITHALA BABU ANVESH
January 25, 2021
Hello @韦哲 ,
I think it's not possible to extend the limit.
Please check the below link.
https://confluence.atlassian.com/jirakb/increase-issue-limit-for-excel-exports-in-jira-cloud-779160811.html
韦哲 January 27, 2021
