Hi, this question was asked, but the answers were NOT very clear.
In "Create Project", we have 3 sections: Software, Service Desk, Business.
We are beginning testing of "JIRA Service Desk", but for now, we do NOT want to show the "IT Service Desk" create project type, in order to reduce confusion.
Explicitly, how can I remove the "IT Service Desk" project type from the "Create Project" window?
Thank you.
Disable the Service Desk application.
The reason the project type is there is to allow your administrators to use it. There's no point in disabling something you want to use.
This question also made me think that you might have some problems with the way you're using Jira.
Nic, thanks for the answer. I am the admin (or the super admin) as we call it. Yes, observation is correct, we are NOT using JIRA the right away. To undo the "bad way" would take months if not longer. Thus we are trying to adjust on the fly, the disabling of the "IT Service Desk" is just a workaround option, due to a conflict of existing custom fields, which we can not modify/delete (for internal reasons), thus I want to avoid using the "IT Service Desk" project, and only use the other 2 projects, "Basic" and "customer service" as part of JSD. It's all just part of a workaround rather than a clean JSD strategy.
