How can I learn properly how to use advanced roadmaps?
CManzano March 27, 2024
I'd like to learn properly how to use Jira roadmaps for scheduling and tracking progress of projects. Is there any course/training you recommend?
I don't exclude paid courses.
Cecilia
Kishan Sharma
Hi @CManzano
There's one free course on Atlassian University - Visualizing Work Across Teams with Plans in Jira Software
Also this - Recorded Atlassian University Live Webinar about Creating Plans and Dependencies in Advanced Roadmaps. Hope this helps.
CManzano March 28, 2024
Thanks Kishan! :)
Mohanraj Thangamuthu
March 27, 2024
Hello, Good day. Check if the following tutorial guide helps you https://www.atlassian.com/software/jira/guides/advanced-roadmaps/tutorials#create-a-plan-in-advanced-roadmaps. Thanks
Thanks Mohanraj! :) Yes, I've seen the tutorials, but I need more information on how to set up a plan.
For example, once I establish dependencies, add the duration (e.g in hours) and assign resources, if I change the duration of an issue, I'd like the plan to adjust accordingly.
