How can I read system roll up values for e.g. Rollup story points, Roll up releases, etc.
Hi @Monica Gupta ,
Can you further explain what you´d like to achieve?, perhaps add screenshots from where you want to retrieve the data and where you´d like to add it. That would help the community to check on your request.
David
I have the following Plan, which has a number of roll up values, Story Points, Progress in Story points, Progress in issue count etc. I would like to able to create a filter which shows this metadata for all the issues so that I can display a filter results widget displaying how much each issue is done in a widget on a dashboard.
Hi @Monica Gupta ,
According to a community answer: Story points roll up, in Advanced Roadmaps there is a "roll-up" feature! Please try selecting "View Settings" in the top left of your plan, then checking the "Others" box in the "Roll-up" section.
Kindly review the comment and let me know if you have further questions.
David
David, thanks for your input. My question was how I can display the same "Rollup" attributes I see in plans to come up in filter queries?
Hi @Monica Gupta ,
Unfortunately, you would need to use automation rules to roll up the value and store it into a custom field for the issue type you want it to be rolled up.
Here is KB document that shows how: https://confluence.atlassian.com/jirakb/automation-to-sum-up-story-points-of-stories-in-different-statuses-and-add-the-value-to-the-parent-1108673757.html
David
