How can I search an issues linked to another issue?
Khushboo August 30, 2018
I want to do Advance Search for issues which are linked to another issue but unable to do that using linkedIssues(ABC-123) function as it is showing me an error such as attached. Please help me to get a solution to this.
Not sure what is going wrong in a syntax of JQL as I have added this with reference to the below link:
https://confluence.atlassian.com/jirasoftwarecloud/advanced-searching-functions-reference-764478342.html#Advancedsearching-functionsreference-linkedIssueslinkedIssues()
Your quick response is much appreciated.
Thanks in advance!
4 votes
Tarun Sapra
Hello @Khushboo
Here's the correct syntax
issue in linkedIssues(CT-560)
4 votes
Manon Soubies-Camy
Hello @Khushboo,
If you look at the Examples line in the documentation, you can see:
issue in linkedIssues(ABC-123)
So you just need to add issue in before linkedIssues(CT-560).
Hope this helps!
- Manon
ohh yes, I saw the same later.
Thanks for your reply.
