You can use ScriptRunner Listener to delete link if linked issue is not from current project.
import com.atlassian.jira.issue.link.IssueLink
import com.atlassian.jira.event.issue.IssueEvent
import com.atlassian.jira.event.issue.link.IssueLinkCreatedEvent
def issueLinkManager = ComponentAccessor.getIssueLinkManager()
Issue currentIssue = event.getIssueLink().getSourceObject()
def currentProject = currentIssue.projectObject.name
def linkedIssue
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
issueLinkManager.getOutwardLinks(currentIssue.id).each { issueLink ->
linkedIssue = issueLink.destinationObject
if( linkedIssue.projectObject.name != currentProject )
issueLinkManager.removeIssueLink(issueLink, user)
thanks,i want to write this code in listener and i have this error
unable to resole class "import com.atlassian.jira.event.issue.link.IssueLinkCreatedEvent"
Did you used IssueLinkeCreatedEvent? I have to some errors, but listener work good.
What version of Jira and Script Runner you have? Can you past here error?
Unfortunately Issue Linked Event was add in Jira 7.5.
i resolved my problem with this code,thank you for your help
import com.atlassian.jira.project.Project;
import com.atlassian.jira.project.ProjectManager
import com.atlassian.jira.event.issue.EventUtils
Issue issuesou=event.issue;
Issue currentIssue = issuesou
def currentIssueId = issuesou.getId()
def linkedIssue = issuesou
issueLinkManager.getOutwardLinks(currentIssueId).each { issueLink ->
linkedIssue = issueLink.getDestinationObject()
if(linkedIssue.projectObject.name != currentProject )
It is not possible.
You could use this add-on for it:
https://marketplace.atlassian.com/apps/1216498/easy-links-for-jira?hosting=server&tab=overview
Hi @reza azad,
Welcome to the community.
You can do this by editing the permission scheme for your project (You must be an Administrator to do that). You should make sure, that the permission scheme is used only in your project, otherwise create a copy, edit that and assign it to your project.
There is a permission for linking issues. If you remove all associated roles, users and groups, nobody can create an issue link anymore.
