How can i get Structured issues hierarchy using JQL query? wants to create filter out of it...
surendra@ondotsystems.com April 5, 2018
Qst: How can i get Structured issues in same hierarchy using JQL query as filter results?
Purpose: Wants to create filter out of it, and use it in timeline control, so that i can see same order/hierarchy against time.
ex:
Structure1
+ EPIC1
++ Ticket1.1
++ Ticket1.2
+ EPIC2
++ Ticket2.1
Query Filter result should be :
EPIC1
Ticket1.1
Ticket1.2
EPIC2
Ticket2.1
Andreas
April 5, 2018
Did you already have a look at Structure for Jira - Projects at Scale?
This is all about bringing hierarchy to your JIRA projects.
Thanks for the reply Andreas...
I dont see "Structure.Gantt" option of while creating structure, we use older version jira 6.* is that the problem?
Andreas
April 5, 2018
Yes, this could be a problem, since the plugin only supports Jira Server 7.2.0 - 7.8.2
https://marketplace.atlassian.com/plugins/com.almworks.structure.gantt/server/versionhistory
surendra@ondotsystems.com April 8, 2018
Upgrading to latest version worked, Thanks Andreas.
Andreas
April 9, 2018
Great! Glad I could help.
