How can i view conflunece page in a jira issue
Guy October 4, 2020
I am using several systems from Atlassian.
2 of them are Jira software & Confluence.
All of our Product Stories are written in Confluence (in our "Product" space)
Is there a way to show in the issue the content from the confluence  in a jira issue?
without adding basically the entire R&D team to a system where I only need the  product team to be?
thanks
G
Guy October 15, 2020
Thank you everyone, basically I see that there is no real built-in way to do it.
caglad
October 4, 2020
Jack Brickey
But that will take the user to confluence and they must have a license to be able to view the page
caglad
October 4, 2020
Then I would do the export to pdf on Confluence and attach it to your issue
Jack Brickey
Yes. That was my recommendation to Guy initially. Not ideal but it is something.
Jack Brickey
You could consider exporting the page to pdf and attaching. This makes sense if the page is ultimately static with few ongoing changes.
yaniv.shoshani
Hi Guy,
You can view Confluence pages in Jira issue by using our C4J addon:
You can try it here:
https://marketplace.atlassian.com/apps/1222263/c4j-content-display-for-jira?hosting=server&tab=overview
BR,
Yaniv
Jack Brickey
This is only available for server, correct?
yaniv.shoshani
Yes.  A cloud version will be availabke soon.
Darko Gebaei
December 20, 2021
@yaniv.shoshani any news about the cloud version availability?
yaniv.shoshani
It is work in progress. Hope to have a beta version soon.
Yaniv
