How can query issues that has links to an issue in another project
Herman Xiao May 12, 2018
Deleted user May 12, 2018
Hi Herman,
Do you use JIRA Server or Cloud?
If you use JIRA Server there is a request to be able to accomplish this, and it seems like it's been added to the Atlassian roadmap:
https://jira.atlassian.com/browse/JRASERVER-25640
If you use JIRA Cloud there is the equivalent request:
https://jira.atlassian.com/browse/JRACLOUD-25640
, but according to the latest update it seems like there is no plan to implement this feature for the Cloud. If you check the comments though, there are some suggestions related to plugins (e.g. ScriptRunner for JIRA Cloud)
Hope it helps,
Carlos
Thanks, do you know a way to do status update when the blocking issue had been resolved/closed?
