How do I assign an issue in post functions based on the project its in?
Wanda L. Lugo
At this time most projects are using 1 workflow and all newly created issues, regardless of project, go to a Status of MGT Review and are auto-assigned to 1 person, Steve.
Now we have multiple projects, with multiple managers using the same workflow.  Example:
Estoris - Steve
DTS - Marybeth
ECA - Dave
Because there are different managers for each project, I want to auto assign the issues based on the project.  So I want all newly created issues to continue going to the MGT Review status but if its an ECA project, I want it to auto assign to Dave.  If it's DTS, I want it to auto assign to Marybeth, etc.
How do I create a condition that says if project = "Estoris", then auto assign to "Steve",  If project = "DTS" then auto assign to "Marybeth"?
Is there a way to do this?
Joe Pitt
The project lead is the default 'auto assignee' for any project. Simply make these users the project lead of their project
Wanda L. Lugo
ok thank you.
1.  I found the project leads are automatic based on who created the project.
and
2. Do I still create a post function and select 'Automatic'?  Or do I simply NOT add a post function?post func1.PNGpost func2.PNG
Joe Pitt
In editing the project you can set the default assignee to project lead.
Joe Pitt
no post function is needed
Wanda L. Lugo
Thank you very much.  Will this apply if I have an auto assignment somewhere else in the workflow?
For example, once it passes development and goes to QA, i'd want the issue to auto assign to a QA lead within that project.  Is it possible to this just like we did with the newly created issues?
