I have done
When: Version released
If: Issues fixed in versionpresent
Then: transition the issue to DONE, but i get this error
Hi @Kelly Lillis,
If I read your description correctly, you should use an automation branch where you seem tp be using a condition.
Your rule should look like this:
Apart from the logic of the rule, the workflow your issues are following should also have a transition from resolved (or any other status you'd like to transition issues from) to your done status.
Hope this helps!
That is exactly what I did wrong. This did the trick thank you!!!!
